Results 41 to 80 of 104
  1. #41
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by QuattroS5 View Post
    I'll confess that after reading this thread I got a little worried and just ended up bringing my car to my local Audi dealer and had them do the install. I LOVE this upgrade!! I don't think SLU_55 could have said it any better as this is a HUGE improvement in throttle response and in mid to high range torque!! I have a GMG Quad Exhaust system and while I wouldn't say there is a very noticeable difference in sound; I do notice it sounding a tad more aggressive!! Def worth the upgrade!!
    Thank you for the great feedback! We really think it's a great bang-for-the-buck modification.
  2. #42
    Jan 05 2015
    Texas
    is this the same thing as an aftermarket intake pretty much?
  3. #43
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by LiLS View Post
    Some aftermarket intakes replace the filter or airbox, but we've found that the factory throttle body hose is the biggest restriction. The airbox itself flows quite well.
  4. #44
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    please make this for the rs5
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
  5. #45
    Nov 26 2013
    houston
    Just ordered one. #*****6691. Looking forward to install it...
  6. #46
    Senior Member Three Rings NavajoS5's Avatar
    Jan 07 2013
    DE
    about to order this up!!!!!! and combine in with my Pipercross filter
    -Rico
    2008 S5 4.2L | Phantom Black Pearl | Premium Black Leather seats | Carbon Wrapped Aluminum inlays | Adaptive Xenons | Meisterschaft Exhaust | MMI | Navi | B&O | Alu Optics Package | RS5 Grill | Tech Pckg | Adampolishes Clean | Miltek Non-res Downpipes | Straight piped | 034 mounts package
  7. #47
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by queenmoka View Post
    Quote Originally Posted by NavajoS5 View Post
    Thank you for the orders!
  8. #48
    Jan 07 2013
    DE
    No problem order #.....6755
    -Rico
  9. #49
    Nov 26 2013
    houston
    The smaller 90 degree barbed fitting for the smallest hose that attaches to the inlet hose was clamped on to the new air inlet hose at the wrong angle, how do you move it at the right angle? Do i need to remove the fitting clip?......
  10. #50
    Sep 17 2005
    Fremont, California
    It can be rotated by hand; no need to remove the clamp.
  11. #51
    Nov 26 2013
    houston
    Quote Originally Posted by 034Motorsport View Post
    Well finally did it, it was a bitch to fit the small hose back. Broke of course one side of the plastic clamp(big hose) but did secure it back with some zip ties. Looking forward to try it tomorrow.
  12. #52
    Jan 07 2013
    DE
    So here goes my review: nothing was really an issue for uninstalling the stock, was out in less than 2 minutes. Installing the 034 was simplified by lubing up the tight fitting parts with the excepting of that damn small hose, tighter than a virgin smh, but I used force without breaking anything, no pun intended. Post installation, didn't notice anything on revving, so I did what I did when I installed the pipercross filter, just reset the ecu, and re-learn everything. Test drove, definitely a smoother louder sound, can feel it when you touch the pedal, I feel like my air flow is even. BTW I have milltek non res downpipes, xpipe and meisterschaft exhaust. Pretty loud as is, but now smoother thru all power bands. Besides that, you can simply see the difference in sizes and how the stock has ripples plus the choke down on entry, don't mind my hands, I'm not a normal sized human
    -Rico
  13. #53
    Active Member One Ring DrewS5's Avatar
    Apr 03 2015
    Montreal
    Hey, thanks im going to be doing this shortly..
    How much time did it take you,? And where did you get your grill. I have a 09 V8 S5. Im looking to get a grill like yours. Thanks -DrewS5
    DrewS5
    DrewS5---MTL
  14. #54
    Jan 07 2013
    DE
    Well actual work took about 15 minutes, I took a break in between because it reached about 95 degrees in my garage lol. And motor was still hot AF. Lol. My grill is OEM rs5 grill from LLtek quite costly but I originally had the replica until the animal I hit broke it, so I upgraded thru insurance OEM, and upgraded brackets you see under it. Much more sturdy than stock. I want the rs5 bumper from LLtek, next mod perhaps.
    -Rico
  15. #55
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Any update on RS5 inlets hoses or air box? ECS says they have plans to release something. Be nice to have for the summer.
  16. #56
    Senior Member Two Rings jwr9152's Avatar
    Apr 08 2015
    Pensacola, Florida
    In case anyone is interested, it does fit on a 4.2 V8 with APR supercharger. Installed it this morning. It's tight, and it's not easy, but it does fit.
    [IMG][/IMG]
    2011 S5 6 spd 4.2 V8 with APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, Meisterwerk short shifter, 034 transmission mount, Stoptech BBK, carbotech xp12, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace, Advanti Hybris 19X9.5, Michelin Sport Cup 2 275/35/19. USP RS5 grill. 034 Motor Mounts
  17. #57
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Jimmy ny View Post
    Still looking for a local car that would be able to stay here for a bit to model things up. We'll give updates as soon as we can.
    Quote Originally Posted by jwr9152 View Post
    Thanks for the photo! The APR SC does move the TB around a bit, so it's definitely a tighter fit without the compliance of the stock accordion hose. Glad to hear you were able to make it fit!
  18. #58
    Sep 17 2005
    Fremont, California
    Thank you for the continued orders!
  19. #59
    Aug 30 2013
    KY
    What is the current price?
    SLOWER TRAFFIC KEEP RIGHT
  20. #60
    Sep 17 2005
    Fremont, California
    We still have a few left at the initial Introductory Special Price of $99.75! You can click the link below to order through our website.
    B8 Audi S5 4.2L FSI V8 Air Intake Hose
  21. #61
    Veteran Member Three Rings Hatchman's Avatar
    Jan 14 2014
    B8 S5, G35, C-Max
    Huntersville, NC
    You squeeze on the two tabs (one tab shown below, since the customer car we used for instructions had another intake piece on it that was installed by the owner) to release the clip. Pushing down on the connection at the same time helps ensure that the clips unseat. You then pull up on the connection to remove the hose.
    No special tools are needed; the connection is designed to be able to remove by hand. I've made an illustration below to help better explain the process, so I hope it helps! If we get another car in with the stock intake hose on it, I will try to take a video of it. We just don't get too many V8 S5s in the shop here lately.
    I just noticed that in your pic, half the shroud we are fighting with is already broken off. Your bottom red arrow is pointing to where the other half of the shroud is supposed to be.
    That thing is a PITA!
    2010 S5
    Meteor Grey, Tuscan Brown, Tip, Prestige, Nav, B&O
    Borla Exhaust / AG M510 / H&R Springs / 034 Motorsports Motor,Transmission Mounts / Akebono / CR-15 / RS5 grill / E-Codes
    HEX-USB+CAN
  22. #62
    Sep 17 2005
    Fremont, California
  23. #63
    Dec 26 2008
    STL
    I installed this hose a few weeks ago when I was putting my engine back together. It's really a phenomenal design.
    One problem I have is the factory engine cover(FSI V8) does not fit well. It kind of bumps on the air intake hose and rests on it. I have an 08 and I know audi re-designed covers for 2009+
    Does the factory engine cover need to be trimmed?
  24. #64
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Slobo7x View Post
    I don't believe the engine cover required any modification on the installations we've done here. That being said, I'd try rotating the hose with both clamps loosened to see if you can get more clearance. Feel free to PM or email me installed pictures so that we can take a look.
    - Laszlo
  25. #65
    Dec 26 2008
    STL
    PM Sent. let me know your email, so I can shoot over some pictures.. I'm pretty sure I have it installed correctly, there is really no other way to do it due to air ports on the side.
  26. #66
    May 18 2016
    Orlando
    I clicked the link but it only shows the 110.20 price. How can I get the $99 price?
  27. #67
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Sofreshs5 View Post
    Unfortunately the Introductory Special ended quite some time ago for these. I apologize for the confusion! We do have them in stock and ready to ship, though.
  28. #68
    Sep 17 2005
    Fremont, California
    These are in stock ready to ship! Place your order today so you can have it before the weekend.
    https://store.034motorsport.com/sili...2l-fsi-v8.html
  29. #69
    Sep 17 2005
    Fremont, California
  30. #70
    Sep 17 2005
    Fremont, California
  31. #71
    Sep 17 2005
    Fremont, California
    Weren't able to make it out to Summerfest? No worries we got a video with some of the action!
  32. #72
    Sep 17 2005
    Fremont, California
  33. #73
    Sep 17 2005
    Fremont, California
    We just came back from Fastivus! Who saw us out there?
  34. #74
    Sep 17 2005
    Fremont, California
    Thank you for all the orders!
  35. #75
    Sep 17 2005
    Fremont, California
    We just posted our recap of Fastivus!.
    034Motorsport at Fastivus!
  36. #76
    Sep 17 2005
    Fremont, California
  37. #77
    Sep 17 2005
    Fremont, California
  38. #78
    Sep 17 2005
    Fremont, California
    A look back at Big Socal Euro! Did any of you swing by the booth?
    BIG SOCAL EURO 2016 | AN EVENT FOR ALL
  39. #79
    Sep 17 2005
    Fremont, California
    Don't forget that we also have transmission inserts and mounts!
    STREET DENSITY TRANSMISSION MOUNT UPGRADE
    034MOTORSPORT TRANSMISSION MOUNT INSERT
  40. #80
    Sep 17 2005
    Fremont, California
    This week only, we're offering Free Domestic Shipping for all orders over $75, and Free International Shipping for all orders over $500!
    Click Here to Get Your 034Motorsport Go Fast Parts!
    Terms & Conditions: Free Shipping Promotion valid for retail customer orders placed between 12:01 AM Pacific Time on Saturday, October 15th and 11:59 PM on Sunday, October 23rd. Cannot be combined with other Discounts, Promo Codes, Gift Cards, Quotes, or Coupons.
    Cannot be applied to orders retroactively. Must select Free Shipping option during checkout.
